Alignment question!?
Old Nov 24, 2018 | 01:08 PM
Dkarll88's Avatar
Dkarll88 is on a distinguished road
Default Alignment question!?
Just had my alignment checked on my 95 4wd blazer 2 door. It was out of spec on my camber on both sides. Caster as well but my cam bolts are maxed out. I am -0.7 on the left and -1.0 on the right for camber. Specified range is -0.5 to 0.5. My question is what is the stock adjustment range of this cam bolt so i know which kit i need to order. Thanks
Old Dec 9, 2018 | 10:38 AM
Dkarll88's Avatar
Any help at all would be great....
Old Dec 10, 2018 | 10:25 AM
I would think that the inability of the shop to align your front end would be evidence that there is a part or parts that are broken or that your frame is bent. There are aftermarket ball joints and perhaps also adjusters that could help.
Old Dec 10, 2018 | 04:18 PM
If you have your torsion keys cranked, then you'll have a problem with you chamber. Your best bet is to check them, lower if need be, or search into aftermarket solutions.
I cranked my torsion keys after I installed an add a leaf kit, needed because my rear end was sagging. Ended up maxing out my chamber adjustments and it still sat slanted. Ended up upgrading to a 2.5 lift kit by rough country.
Last edited by DonL; Dec 10, 2018 at 04:20 PM. Reason: Added more info not originally entered.
Dannyn01
Aug 3, 2018 11:11 PM
95blazerlt
Mar 8, 2014 05:40 PM
bdemutis
Lifting Tech
Apr 18, 2013 11:07 AM
Jase1979
Jun 21, 2012 06:00 PM
99bblazer99
Lifting Tech
May 21, 2012 07:00 PM
