blazer "rolls" back and forth over highway bumps
Old Nov 18, 2015 | 07:05 PM
Greg Peterson's Avatar
Greg Peterson is on a distinguished road
Default blazer "rolls" back and forth over highway bumps
I have a 2000 ZR2 - I put new front shocks on it last year, and I just had the upper and lower balljoints replaced, the idler arm replaced and both wheel hub assemblies replaced as well as had the front end aligned. The problem I have now is that the blazer rolls from side to side when going over highway bumps but keeps good control and stays planted to the ground - it just feels like you're on a rollercoaster and the vehicle sways from side to side before settling back down after hitting uneven patches of pavement on the highway. The mechanic never said anything about my sway bar being bad or anything. Does anyone have any ideas on what this could be?
Old Nov 19, 2015 | 03:37 PM
Toocute350's Avatar
Toocute350 is on a distinguished road
It sounds like it there might be a problem with either the sway bar bushings or the sway bar`s themselves.
Old Nov 19, 2015 | 05:18 PM
I believe you are correct - upon inspection today I see that the end links are bad. I'll replace both those and bushings and see if that fixes it - it should.
Old Nov 19, 2015 | 09:08 PM
Toocute350's Avatar
Yes..The sway bar does what it say`s..It keeps the vehicle from swaying side to side.Not front to back.Front to back is controlled by the front springs, rear springs, shocks.Make sure you have sway bars front and back,check to make sure their not cracked any where`s.
Old Nov 20, 2015 | 01:28 AM
It's pretty stout but will check it when I take it off to change bushings. Thanks for your help!
er0ck273
Sep 1, 2013 11:45 AM
jmaynard
Aug 28, 2010 03:56 PM
soundguy
Sep 20, 2007 03:23 PM
98blazergal
Nov 5, 2006 01:49 AM
beilharzc
Mar 12, 2006 01:50 AM
