Cant find the issue, 4x4
im thinking vacume problem.
thats possible the cable is not being pulled enough to engage the front axles
thats what happened to my truck till i replaced it
So I go out and measure how far its being pulled in and if its not being pulled in enough, can i replace the cable or does that mean that actuator under the battery needs replaced?
depends if the cable is not locking the front axles the cable has to be seized or something
what you can do is disconnect it from the vac diaphram and pull it manually then lock it with a pair of channel locks
then test the 4wd
then test the 4wd
Ahh ok. I never thought about that. KK Ill check it tomorrow. Do I pull it out all the way til it stops?
yup i think its about 1/2 inch or 3/4 if i remember right
Guest
Posts: n/a
s10extremist.org I just did this it could be your problem. Have seen it a couple of times. Bit of a PITA and if its not..... very disapointing.
I hope its not that. If it is, then Ill just hot rod it til its finally done and go back to Jeep lol. This thing is starting to give me headaches
RexCastle
11-13-2012 07:05 AM
PROJECT85K5
12-06-2009 10:55 PM
