drive axle removal
Old Jan 10, 2008 | 03:36 PM
tilley101's Avatar
tilley101 is an unknown quantity at this point
Default drive axle removal
what is the best way to remove the front drive axle on a 4x4. i remove hub,steerring, rotors everything except spindle. i cant get the spindle off. i tried turning the wheel all to push it out of the side but im not sure if i should be using so much force.
What would be the easiest way to remove the drive axle out of the spindle?
Old Jan 10, 2008 | 04:40 PM
HeyYou's Avatar
HeyYou is an unknown quantity at this point
Default RE: drive axle removal
It should just pop out toward the center of the truck.What I generally do is: Take off the six (eight?) bolts holding the axle inner hub to the drive flange, take off the nut on the out end, position the axle so I can back it toward the centerline of the truck some, crank the wheels all the way to the lock, and tap gently with a hammer till the axle comes loose, then just wiggle it around till I can pull it out.
Alternatively, you can take the spindle loose from the ball joints......
Old Jan 11, 2008 | 11:01 AM
Logan's Avatar
Logan is on a distinguished road
I beleive you remove the tierod from the spindal,so the spindal can turn enough to pull the axle out.
mirrorimij
Jun 8, 2019 03:34 PM
Blade_24k
Feb 26, 2014 03:03 PM
drodr05
Sep 24, 2010 02:15 PM
lizzj70
Jun 23, 2010 06:57 PM
carterx
May 21, 2009 08:30 PM
