Front Axle housing seals and bearings removal
Old Dec 15, 2012 | 10:27 AM
benthm7's Avatar
benthm7 is on a distinguished road
Default Front Axle housing seals and bearings removal
I own a 1998 Chevy Blazer part time 4X4. I need to know, do you really need too remove the shaft tube housing for removing and installing seals and bearings, can I work with the tube house assembly bolted to the frame? Please reply ASAP
Old Dec 15, 2012 | 10:44 AM
Blazin00LT's Avatar
Blazin00LT is on a distinguished road
You can change the cv axle seals while on the vehicle. Not too hard.
Old Dec 16, 2012 | 09:55 AM
abig84's Avatar
bearings you will need to remove and disassemble the front differential. the seals you can do with it in the truck. if the bearings arent bad leave them alone those things suck to get out of these trucks
Old Dec 17, 2012 | 06:16 PM
benthm7's Avatar
You mean only tube housing where the seals and bearings is sitted, right.
The seals and bearings are sitted at bell of the housing, why? the seals and
bearing cann't be remove together and not have to remove the tube housing from
Old Dec 25, 2012 | 04:25 PM
98s104by4's Avatar
98s104by4 is on a distinguished road
I am having an issue replacing/installing my new cv axel shaft. I replaced 2 times already, 3rd soon,. My question is when i removerd the old shaft a 12" steel rod also.
When I bought the new shaft it didnt have the 12' steel rod, the guy poped it off for me. Well I slipped it back in and gave it a gentle hit to assue myself it popped in. In repalcing new shaft I put back in as the way I took out. The new axel seemed to make thumping noise and a rumbling noise. Any suggestions? Is there a specific way to properly install cv shaft? It seemed like a very easy job. 1998 s10 4x4
Bobcat13
Aug 31, 2014 06:38 PM
bertrenolds
Nov 7, 2012 03:05 PM
xgiovannix12
Sep 16, 2011 09:14 PM
brians1bad72
Mar 24, 2011 05:13 PM
blkblazer
May 30, 2009 09:17 AM
