front diff ???
Old Mar 23, 2008 | 11:50 AM
97BlazerLS's Avatar
97BlazerLS is an unknown quantity at this point
Default front diff ???
I was wondering what is the hardest part of taking out a front differential out of a 97 blazer?
Old Mar 23, 2008 | 07:53 PM
Default RE: front diff ???
There really isn't anything too complicated about removing the front differential... You basically just take things apart. You will need to disconnect the front drive shaft. Disconnect the front axle engagement cable. Next is how I would do it... Disconnect the lower ball joint, then pull the front CV shafts from the front diff. Do this on both sides. You then may have a breather tube and remove the bolts holding the diff to the frame and lower it down and out.
dagda
Jan 12, 2010 06:37 PM
ComputerNerdBD
Mar 18, 2009 06:13 PM
Marcin
May 29, 2007 03:17 PM
Aquahallic
Aug 5, 2006 01:37 PM
slayer6x6
Dec 8, 2005 02:24 PM
