front diff ???
There really isn't anything too complicated about removing the front differential... You basically just take things apart. You will need to disconnect the front drive shaft. Disconnect the front axle engagement cable. Next is how I would do it... Disconnect the lower ball joint, then pull the front CV shafts from the front diff. Do this on both sides. You then may have a breather tube and remove the bolts holding the diff to the frame and lower it down and out.
ComputerNerdBD
Mar 18, 2009 06:13 PM
slayer6x6
Dec 8, 2005 02:24 PM
