front diff bearings, 96 blazer
Old Mar 29, 2010 | 06:15 PM
  #21
jacobcnc's Avatar
jacobcnc is on a distinguished road
I never changed the bearings i just swaped the whole set up from one in a junk yard.
I still think if you take it apart you will see the problem.
Old Mar 29, 2010 | 06:34 PM
  #22
The cable pulls on the shift fork in the front axle to engage the collar onto both gears (the one connected to the differential and the one on the passenger side extension shaft). When you put it into 2HI, the spring inside (not the one you found - further inside) pushes the shift fork back to its neutral position disengaging the collar.
The pieces I am talking about can be seen in the images found in the link I posted above.
Old Mar 29, 2010 | 11:12 PM
  #23
alphawolf88's Avatar
alphawolf88 is on a distinguished road
what i found i guess would be a retainer, keeper, not really a spring. i once againg tried pulling on the fork assy, im only getting 1/8 travel, not the .5 to .75 you have talked about. im going to drop the axle assy this weekend so i can see whats going on. i have called around junk yrds for parts, nothing.
Old Mar 29, 2010 | 11:28 PM
  #24
jacobcnc's Avatar
Go to a pick a part or a upullit type yard they are always cheaper or you could just do a bravada/astro upgrade
Old Mar 30, 2010 | 06:42 AM
  #25
Sounds like the teeth on the gears & collar have rounded off and is prohibiting the engagement. You can see the start of the teeth rounding off in the picture from the link I posted above.
As far as the Bravada/Astro upgrade, that will be certain to keep your front axle engaged all the time, however, it will not be as nice on fuel economy. If you just swapped the passenger side extension tube and axle shaft, you could cut down on your cost. I still think your diff is perfectly fine.
Old Mar 30, 2010 | 06:53 PM
  #26
jacobcnc's Avatar
Tell you what i will send you the tube shaft collar every thing on the side you pay shipping i have two laying round shipping will probly be like 25 dollars no sence in throwing away if you need them
Old Mar 31, 2010 | 11:45 PM
  #27
great. i sent you a private message with my ph number, thanks
mkm1387
Mar 11, 2012 08:20 PM
EnyChevyUK
Mar 21, 2009 07:55 PM
ComputerNerdBD
Mar 18, 2009 06:13 PM
phantom
Aug 21, 2007 06:52 PM
yzf125
Sep 17, 2005 11:45 PM
