Front diff carrier gear
Old Oct 18, 2014 | 09:31 AM
cdlcbc's Avatar
cdlcbc is on a distinguished road
Default Front diff carrier gear
96 blazer tcase switch bad (now changed). where can I find info on switching the front diff carrier gear set on as mine is bad...grinding non engagement of right axle I saw a few posts sometime ago but can't locate them now. Any help or direction will be appreciated thanks
Old Oct 18, 2014 | 10:15 AM
rexmburns's Avatar
Super Moderator
Honestly your best bet is to just swap the entire front diff. You can find them cheap and swap them in inly a couple hours as opposed to trying to swap internals.
Old Oct 18, 2014 | 10:26 AM
cdlcbc's Avatar
Thanks this gear is the one that the shift collar pulls over to couple the output shaft and right front half shaft. I am hoping from what I remember this is easier than the whole diff
Old Oct 18, 2014 | 10:44 AM
If it is just the front axle engagement that is causing problems, then you can pull the extension tube and inspect the engagement mechanism. If driven with the drive coupler slipping, you may have to replace the coupler and the mating gear as the wear will prevent proper engagement. THIS THREAD in the Tech Article (DIY) section has details concerning the front axle engagement mechanism inside the axle.
Pulling the extension tube is easier than pulling the entire diff, but you still need to remove the half shaft from that side before removing the extension tube which can be a pain.
Old Oct 19, 2014 | 11:04 PM
cdlcbc's Avatar
Thanks for the info!!!. I do have a question on this 1996 chevy blazer the right half shaft is a bolt on inner is it possible to remove bolts and pull back the half shaft enough to get the extension tube out. I saw reference to this somewhere I just can't remember. Anything to save 5 steps.
Thanks again!
Blazer_boy
Jan 5, 2013 09:33 PM
mafiaboy01
Dec 21, 2011 06:54 PM
dagda
Jan 12, 2010 06:37 PM
gearyr
Nov 28, 2009 07:41 PM
Millertime21
Oct 12, 2008 03:21 PM
