Front diff oil
Old Feb 9, 2017 | 10:13 PM
Corey Ruiz's Avatar
Corey Ruiz is on a distinguished road
Default Front diff oil
My front diff in my 96 blazer is a little noisy, I am wondering if I can put 85w130 oil in it to try to make it quieter without hurting anything.
Old Feb 10, 2017 | 07:42 AM
Brian Hinzpeter's Avatar
Brian Hinzpeter is on a distinguished road
What noise is it making? Is the fluid full and clean? What year is it?
The heavier fluid may help a bit but if you live somewhere cold like me then that heavy fluid may do more harm then good.
Old Feb 10, 2017 | 08:39 AM
Rusty Nuts's Avatar
Welcome to the forum. Using heavier oil to quiet noise is a used car dealer trick. It's like a doctor using a band-aid to cover a bullet hole. If it's only noisy in 2 wd search the forum for 4x4 noisy in 2 wd. Specify whether 3 or 4 button system. If the noise is constant, as Brian mentioned, make sure it's full. Low levels cause bearing groan.
Old Feb 11, 2017 | 11:22 AM
Corey Ruiz's Avatar
it's a 96, it moans when it's cold, cold here is 32 degrees, but it will moan until it warms up even if it's 50 degrees out. I am just trying to find a temp fix until I can afford to have the diff rebuilt
Pur_SSyn
13
Mar 7, 2009 09:44 AM
oisinirish
Feb 6, 2009 07:19 PM
todaresqSL2
Nov 10, 2008 01:47 PM
portcqb
Apr 27, 2008 08:24 PM
joey
Nov 27, 2006 11:32 PM
