Front end completely shakes under speed. Here are my parts to change out. Am I missing anything?
Old Nov 9, 2008 | 06:03 PM
jdpilot's Avatar
jdpilot is an unknown quantity at this point
Default Front end completely shakes under speed. Here are my parts to change out. Am I missing anything?
Did balljoints last year. They check out fine. The front end wobbles at 65 mph +.
So, I am going to replace the following on my 97 blazer with 200000miles
-Pitman
-Idler arm
-Tie rod ends (inner and outer???)
-Wheel bearings (left and right)
Anything else I am missing in this project???
Old Nov 9, 2008 | 06:48 PM
Default RE: Front end completely shakes under speed. Here are my parts to change out. Am I missing anything?
Why not start by checking those components and only replace the ones that show play?...
Old Nov 12, 2008 | 03:17 PM
Clay_Assassin's Avatar
Clay_Assassin is an unknown quantity at this point
I'm with Kyle. You may replace all that stuff to find out your steering box is shot, which is pretty typical on these blazers from what I've seen. Find out what's bad, then replace.
Old Nov 12, 2008 | 03:54 PM
AJBert's Avatar
Agreed, and four parts you forgot is upper and lower control arm bushings. Might also want to check sway bar bushings and the steering stabilizer, if so equipped.
Old Nov 12, 2008 | 06:01 PM
Millertime21's Avatar
Millertime21 is an unknown quantity at this point
I had a shake up front not to long ago. My buddy suggested to rotate my tires (hadn't been done in over a year) and now it rides nice and smooth. Just an idea.
96chevy4dr
Sep 27, 2012 02:02 PM
Coco808
Jun 26, 2011 02:49 AM
zcat23
Sep 29, 2010 10:30 AM
lizardqing
Nov 21, 2009 03:30 PM
mellon101
Nov 28, 2006 06:21 PM
