Front end Squeal/Squeak/Sqwak
Old Dec 28, 2008 | 09:41 PM
livinterror's Avatar
livinterror is an unknown quantity at this point
Default RE: Front end Squeal/Squeak/Sqwak
Did you ever find out what all the squeaks were?
Old Dec 30, 2008 | 03:44 AM
bertrenolds's Avatar
bertrenolds has a little shameless behavior in the past
I would say that if you are moving and or turning at the same time and it squeeks with no brakes being applyed it is the hub bearings, could be the brakes to. Might need new hub bearing or then could just need to be greased.If your sitting still and you bounce up and down on the front end or rear and it squeeks it's the shocks. And for the boot for the axel behind the the ball joint plate, your gonna have to remove your ball joints, both of them to get at that boot, not to hard and can be done with hand tools, just set alot of time aside as you will probably run into other problems along the way. But once you get the ball joints disconnected you can get a replacementaxel and it will bolt right up to the transfer case, not to hard. When you pickel fork the ball joints to seperate them from the plate you are probablygonna have to replace them or the boots on them because more then likely you are going to damage the boots in the process of seperating them from the plate. I will try to get the video I made up asap so everyone can watch the process.
94s10blazin
Sep 24, 2018 10:38 AM
lionel2
Sep 29, 2012 03:52 PM
WickedBlazer
Sep 12, 2012 03:14 AM
6lbsledge
19
Jan 19, 2012 11:17 PM
thrash902
Sep 15, 2010 10:52 PM
