Going from non-high rider to high rider axels?
Old Jul 22, 2017 | 02:58 AM
959900s10blazer's Avatar
959900s10blazer is on a distinguished road
Default Going from non-high rider to high rider axels?
Hi guys!
So I have to replace my drive side cv axle and I was just wondering how much of a ride height difference is there between a standard 2000 4wd blazer and the ones with the "high rider" or ZR2 option. Can I change my axles on my standard blazer and it still function properly or is it risky? Thanks!!
Old Jul 22, 2017 | 07:47 PM
AJBert's Avatar
The ZR2 sits about 3 inches higher and about 4 inches wider than the stock Blazers. They also have different mounting points on the frame and a different frame. Pretty sure you can not swap the CV axles.
Old Jul 23, 2017 | 05:33 AM
newguy's Avatar
Dont believe its high rider, think its higher WIDER. and yes it wont make you truck higher, it will just look funny because your tires will be wider
Old Jul 24, 2017 | 01:59 PM
El_Beautor's Avatar
Like AJBert said, the CV axles are not compatible between the ZR2 and regular Blazers.
Old Jul 24, 2017 | 02:06 PM
newguy's Avatar
Yes, front axles will not fit
dpannazzo
Jun 28, 2013 04:40 PM
97CountryJukeboxLt
Dec 14, 2010 07:31 AM
ericthughes
Apr 24, 2010 09:24 AM
Tippman7641
The Chop Shop
Mar 13, 2008 08:34 PM
1blkblazer422
Jan 24, 2008 04:44 PM
