Hell between the tires
Old Dec 25, 2008 | 12:07 PM
Johns1987Blazer's Avatar
Johns1987Blazer is an unknown quantity at this point
Default RE: Hell between the tires
^Exactly since the steering geometry is nearer the lower control arms.
Old Dec 25, 2008 | 12:16 PM
It does not matter if it is nearer the lower control arms... Those components only modify Toe. Not camber which with the suspension setups on these trucks is modified by moving the pivot point at the front and back of the upper control arm. Moving both of the upper control arm pivot points at the same time modifies camber only. Moving one will modify both camber and caster (the alignment of the ball joint centerlines in the steering knuckle from vertical), but caster more than camber.
kickme005
Tires and Wheels
Jul 17, 2010 07:04 PM
speedfreak81
Oct 13, 2009 06:58 AM
EuroGoldLS
Tires and Wheels
Mar 31, 2007 08:36 AM
EkStreem G
Oct 4, 2006 03:56 PM
swoopes_30
Feb 20, 2006 02:33 PM
