How It Works: GM/Eaton G80
My new silverado has the G80 locker in it and I knew a little bit about it but really didnt know how it was put together and under what conditions it works. So i did a little searching and found this video on youtube (presumably put out by Eaton) that explains in detail just how it works. Take a look. LINK
Never thought to look on YouTube for that! LOL I had seen that video quite a few years ago just not with the new silverado in the beginning. Definitely good stuff!
You can see where the weaknesses of the G80 come from in that video! Good for casual offroad, but start hammering on things and that cross shaft will snap rendering the diff open.
ORIGINAL: TripleBlackBlazer
So G80=traction at low speeds, not good for burnouts above 20mph. Good to know...
I wouldnt exactly say that. I've layed down a good set of tracks doing a brakestandreally getting both tires going.I would venture to say that they were probably spinning above 20mph.
I see what you mean kyle about that cross shaft. I kinda wondered about that guy when i saw the video and went...."So that little sheep s*** thing is what gets hammered on when that engages?!?!" Oh well, my truck is only seeing street and towing use so i guess i wont have to worry about that grenading on me anytime soon.
Though speaking of which, im reading here and there that the G80's need a special gear lube or that it can only take synthetic. Any truth to that or would you know at all Kyle?
Aha, i kinda figured as much. Especially since nearly all of the places citing the need for the "special gear lube" were citing the Texaco lube with the GM part numbers. Sounded a little odd. So Mobil 1 gear lube it will be next time it gets serviced, WOOT!
Problem with that mod is that if you going down the road at 50 mph, you put the back wheel off the shoulder, hits mud/dirt, slows down, it locks in the other side...
Puts you in a tail spin at 50 mph...yikes...
ORIGINAL: WolfPack
My problem with the G80 mod is that cross shaft. I dont think it can handle that kind of stress from 50MPH. That sucker would pretty much grenade i would imagine.
CBlazer99
Feb 2, 2010 10:18 PM
hkellogg
May 30, 2009 10:11 AM
