Intermediate shaft
Old Mar 16, 2011 | 11:35 PM
saxman_IN's Avatar
saxman_IN is on a distinguished road
Default Intermediate shaft
Help...I'm looking for a replacement shaft from the gearbox to the steering column. I'm having a tough time...I found one on ebay, but it's used and I suspect it will have the same worn joint I already have!!!
I need suggestions on a source online. I've checked the usual suspects: autozone, oreilly's and rock auto.
Any help would be GREAT!
Old Mar 17, 2011 | 07:24 AM
keego's Avatar
keego is on a distinguished road
You'll probably have to go OEM. Go to your local dealership.
Old Mar 17, 2011 | 09:51 AM
blazinloud's Avatar
may not be what your looking for, but good info here.
http://www.zr2usa.com/mboard/index.php?showtopic=35735
Old Mar 17, 2011 | 03:35 PM
saxman_IN's Avatar
Default Stealers...yikes!
I was trying to avoid the stealership if possible, but it might come to that soon.
blazinloud, you got me thinking...if the U-joint solution will work on the gearbox end- what about the column end? Anyone have thoughts on this...??? I don't want to do anything dangerous, but why wouldn't that work too?
Thanks in advance!
Old Mar 17, 2011 | 05:09 PM
mr.vls's Avatar
See the link below on how I replaced my intermediate shaft with one from a Jeep Cherokee.
I did purchase a shaft from GM and the rubber for upper tulip joint eventually cracked and the grease was leaking out. The shaft is over $200 from the dealership which I purchased and a few last year I was looking to replace it again. I have had the Jeep Cherokee shaft since last year and I could not be happier and I do not think I would ever have to replace it again. You could also check rock auto to see if they carry the shaft if you still want OEM.
https://blazerforum.com/forum/builds-48/s15-w-jeep-cherokee-steering-shaft-48693/
Gmas95
Jun 20, 2014 03:43 PM
PMeloy
May 10, 2011 03:37 PM
Hellraiser
Mar 24, 2011 05:06 PM
kpzrx
May 28, 2010 12:04 PM
SniperX13
Mar 16, 2006 09:57 PM
