life of shocks
Old Feb 4, 2010 | 10:28 AM
vrryder's Avatar
vrryder is on a distinguished road
Default life of shocks
Just have a question about the life of shocks. My truck has 157k miles on it whats the chances that the shocks are past their prime and should be changed? I know the back ones are bad but should the front be gone too or soon behind?
Old Feb 4, 2010 | 10:41 AM
BlazerGuy2001's Avatar
X2 I have 194xxx miles on mine and I'm not sure if they are stock but they seem pretty worn....when should they be replaced...how can you tell
Old Feb 4, 2010 | 11:28 AM
vrryder's Avatar
im not 100% sure about replacement either. I know my rear ones are gone becuase they cluck real bad so im going to replace them but im not totally sure about the front.
Old Feb 4, 2010 | 11:44 AM
AJBert's Avatar
Bounce your vehicle at each corner. If it stops bouncing almost immediately, the shocks are still good. If it keeps going for a little bit then they need to be replaced. I've got 188K on my original shocks and I see no reason to replace them as of yet.
As long as they aren't leaking and do the job there is no need to replace them.
Old Feb 4, 2010 | 12:01 PM
vrryder's Avatar
The only thing with mine is that it seems like when you hit a bump it almost seems like the front wheels come off the ground and bounce around a bit. I know its probbly an exaggeration about the wheels coming off the ground but thats the way it seems. I know the back ones are bad like i said before bc of the thumping ging over bumps
Old Feb 4, 2010 | 12:42 PM
rriddle3's Avatar
My test method is to push down on each corner 3 times and release on the downpush. If the corner comes up, go back down, and back up more than once (1 rebound cycle), replace the shock.
Old Feb 4, 2010 | 02:58 PM
haha alright sounds good, mine should be alright for atleast a little while...if i do a 2" shackle lift and 1.5" tbar crank should i replace them or will they be ok?
bigdaddykane93
14
May 8, 2014 08:54 AM
jagblazer01
Apr 16, 2009 03:54 PM
fred96
14
Jan 26, 2007 01:23 AM
kakn
15
Dec 16, 2006 05:23 AM
a_tack
Oct 2, 2006 10:55 PM
