Loose Steering
Old Sep 1, 2012 | 02:24 PM
range's Avatar
range is on a distinguished road
Default Loose Steering
The steering on my 2000 Blazer is rather loose. I've have the ball joints, tie rods, center link, etc. all replaced still loose. Someone told me there's a adjustment screw or nut on the steering box which is suppose to tighten the gears or something inside the box. Just wondering if anyone has any experience with this process or does this adjustment screw even exist?
Old Sep 1, 2012 | 10:25 PM
98blazin's Avatar
98blazin is on a distinguished road
Old Sep 2, 2012 | 12:15 AM
Rottidog's Avatar
LOVE that link 98!!! lmao too funny & cool!
Old Dec 16, 2013 | 08:36 AM
TonyZR2's Avatar
TonyZR2 is an unknown quantity at this point
My steering wheel has quite a bit of play also. My mech. Says it's the steering box. Says about $160 labour to get at it.....then tighten. But.............says it would be better, however, it's just guesswork. So couldn't tell me how much better it would get. I asked him, if they happened to make the best possible adjustment, would it be as good as new? Answer to that is, no. So.........better to get a rebuilt for maybe around $350, to put in....at the same time that $160 is being spent to just access it. Maybe even customize it to a 3 turn, lock to lock instead of 3 & 1/2? Either way it should be more reliable than the faulty OEM box.
2002 ZR2 4.3 Vortec
Old Dec 17, 2013 | 11:27 AM
TZFBird's Avatar
TZFBird is on a distinguished road
I have this problem myself and I think it's a combination of wear at every point in the steering system. I suspected the steering box as well on my '95 however there are rebuild kits which include a few small bearings which could be the main problem. Some day I'll get around to pulling mine and rebuilding it. If this thread is still open 6 months from now hopefully I'll have an answer.
But the idler arm is the weak point in the steering system IMO. I'm guessing when that goes out, more wear is placed on the steering box.
Old Dec 17, 2013 | 06:49 PM
Vader's Avatar
Vader is on a distinguished road
Just like several other people, mine has the sloppy steering as well. I was quoted at about $550 for a remanufactured steering box and installtion. Replacing the steering box will fix it, but only until the new box wears out again. I had my idler and pitman arms checked out when I was trying to confirm the box was bad, and the mechanic said they were still tight and good. Isolating the box as the issue.
Old Dec 17, 2013 | 07:29 PM
odat's Avatar
check for a worn rag unit in the steering shaft - under the plastic cover at steering box [ or worm gear is the old term for steering box ]
Old Dec 17, 2013 | 11:14 PM
LeWhite's Avatar
^ rag. Any oil around thr box will migrate tothe rag and decompose it.
Old Dec 29, 2013 | 08:11 PM
alexstep33's Avatar
alexstep33 is on a distinguished road
I v got a 05 blazer 2wd same thing I am making the adjustment to the steering box this week if I get time. has anyone rebuilt theirs yet ?
Old Dec 30, 2013 | 10:51 AM
TZFBird's Avatar
There is a complete writeup with pics on Pirate4x4 site. Doesn't seem very hard aside from getting everything set back correctly.
litterbug
Oct 19, 2011 07:50 AM
ussexplorer
Apr 11, 2010 06:53 PM
injville
Dec 14, 2009 12:10 AM
christine foxx
Oct 14, 2009 01:45 PM
Cuchulain
Jun 17, 2008 05:24 PM
