Miserable UJoints Seriosly.. Nylon retainers?
So after beating my driveshaft for an hour.. did some more searching and found that my stock driveline had a internal nylon retainer holding the ujoint on.. This video was way helpful
Replacing a U-joint in a 1999 Chevy S-10 4x4 - YouTube
Who knew, you would have to melt the clip out to remove the ujoint.
This is exactly what I was looking for. What would happen if you didn't put the shaft on the exact way you took it off, you forgot to make marks. Would you have balance issues and How do you know it's on correctly if you didn't make marks? Does a shop have to balance check it or something?
Because everything I have read say's to mark the shaft so you put it back on the same. Also I was just looking and are the front drive shaft u-joints press out's? They don't appear to be nylon. How do you get them off, do you remove the cap over them somehow?
billyfromhill
Sep 27, 2014 09:57 PM
spittybays
Oct 19, 2012 03:34 PM
volcer
Mar 15, 2012 04:51 PM
