Need help with body mounts
Old Mar 9, 2018 | 02:24 PM
Danlf4's Avatar
Danlf4 is on a distinguished road
Default Need help with body mounts
Have to replace worn out mounts on my 2004 blazer
Do i have to lift my interior carpet up to get to the blots or are they only bolted from the bottom?
Old Mar 9, 2018 | 02:56 PM
rockp2's Avatar
Bolted from the bottom. Except the radiator mounts. You have to take off the grille to access the bolt so you can hold it fast while removing the nut.
Old Mar 9, 2018 | 04:05 PM
rockp2's Avatar
Tip: Do one side at a time so the opposite side keeps the body aligned to the frame. Also disconnect any brake line keepers wire loom brackets that could cause breakage. Also, good idea to disconnect the lower steering shaft from the gear box input shaft.
Old Mar 9, 2018 | 04:12 PM
Danlf4's Avatar
Thank you for the info
lakeblazer91
Feb 25, 2009 07:19 AM
bacardi193
Dec 12, 2008 04:08 PM
greenduster360
Apr 23, 2007 12:30 AM
minijosh
Dec 18, 2006 08:50 AM
offthehop
Dec 4, 2006 10:01 PM
