Pinion seal
Old Jul 9, 2021 | 01:23 AM
dshilling's Avatar
dshilling is on a distinguished road
Default Pinion seal
I recently purchased a 2000 LS with a GU6 diff. The pinion seal needs to be replaced and I have no idea which deal to get after looking at Rock Auto's website. Does anyone know which seal to get? The site differentiates the seals by the size of the ring gear, I don't plan to pull that to measure it.
Old Jul 9, 2021 | 07:27 AM
You need the one for the 7.5/7.6" ring gear.
Old Jul 16, 2021 | 02:09 AM
Mods's Avatar
get a crush sleeve if possible too, monkeying with the original sleeve is going to be more time then its worth.
Old Jul 16, 2021 | 08:17 AM
The only problem with replacing the crush sleeve is that you have to pull the carrier out to set the pinion bearing preload.
As long as you don't overtorque the pinion nut when you put it back on, you're not going to crush the sleeve any farther, so it shouldn't affect pinion bearing preload.
Old Jul 18, 2021 | 10:15 PM
dshilling's Avatar
Default Thanks
Thanks for the input!
Old Jul 19, 2021 | 01:34 PM
LesMyer's Avatar
This above! Torque the pinion Nut to around 175 ft.lb and you'll be golden (tight enough). Should take >300 to crush the sleeve any more than it is.
ps don't try to beat the pinion yoke off - use a puller.
Old Mar 1, 2024 | 10:26 PM
kc8oye's Avatar
kc8oye is on a distinguished road
can't you go blind doing this? LOL
Melissa Keith Sechrist
Sep 3, 2019 10:20 AM
Kusstard
Oct 12, 2017 03:53 PM
SteveFebreze01jimmy
Mar 22, 2010 07:40 PM
sixgunzx2
Nov 30, 2009 02:38 PM
ahawks47
Aug 1, 2008 03:00 PM
