Popping in front suspension
Old Feb 14, 2007 | 12:35 AM
TripleBlackBlazer's Avatar
Default Popping in front suspension
2000 4WD
70k miles
LS trim
Within the last 5-10k miles, I've noticed a 'popping' or 'clanking' noise in my (mostly left) front suspension. It occurs when I drive over a bump or something such as a manhole cover. I only hear the sound when the suspension is extended or released (as opposed to when it's compressed). My mechanic brother suggested the hub bearing, but he's a state away and only going by what I describe. I'm the second owner and my guess is that it needs new shocks or possibly has a loose mount...
Any ideas?
Old Feb 14, 2007 | 12:52 AM
ma96782's Avatar
ma96782 is an unknown quantity at this point
Default RE: Popping in front suspension
Your brother is a state away......think how far the guys on the internet are. LOL
Anyway......IMHO......you could/should take your vehicle down to an alignment shop.....ask them to look her over and give you an estimate. They see hundreds of frt ends during a week......they KNOW their stuff. If you decide to get the parts and work done there, thats good for them. If you take it home and DIYrepairs....at least take it back when you're done and get her aligned there......you will probably need to anyway (after doing major parts changes).
Aloha, Mark
Old Feb 14, 2007 | 10:07 AM
If you do go to an alignment shop, take their assessment with a grain of salt. They do see tons of vehicles a day, but they are in business to make money and often times will recommend anything and everything that they see as possibly being a problem.
IMO, you should check your ball joints. This is a common problem.
Old Feb 14, 2007 | 07:04 PM
ma96782's Avatar
Or better said.....Take it to a shop YOU TRUST!!!
Aloha, Mark
Old Feb 14, 2007 | 11:55 PM
DINO55's Avatar
DINO55 is an unknown quantity at this point
Also Try Greasing all11 zirc's with the wheels off the ground, then take it out for a test ride.
Old Feb 15, 2007 | 01:37 AM
TheBrettster's Avatar
TheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond repute
I had the same problem with mine, it would pop when i went over a bump while turning right or left. Chevy told me for months it was normal but after numerous letters they found the problem. They never stated what it is but they had to replace the lower control arm and idler arm.
fondo
Feb 25, 2009 07:08 PM
sschuler
Jan 5, 2009 03:43 AM
therealdeal770
Sep 21, 2007 10:20 PM
Joey P.
Jun 4, 2007 09:33 AM
bob the blazer
Suspension Tech
Jun 16, 2006 10:13 PM
