Power steering hoses
Old Aug 6, 2013 | 06:38 PM
Ras2466's Avatar
Ras2466 is on a distinguished road
Default Power steering hoses
I have a 99 blazer. One of the hoses is pissing fluid. Need advice and steps to change one or all the hoses. How to get access? So damned right under the hood! Thanks in advance!
Old Aug 6, 2013 | 07:01 PM
Plenty of room if you remove the air filter housing, you can get right at the hose connections.
Old Aug 6, 2013 | 07:12 PM
Twip's Avatar
the air filter housing only has one 10mm nut and a hose clamp. everything else is pressure fit. just pull on it firmly after you remove the nut.
Old Aug 7, 2013 | 01:05 PM
abig84's Avatar
those ones on the gear box are usually very rusted, spray rust buster on them. or since you are replacing it anyways you can just cut the line close the the nut part and then use a socket with extension to help you get it off.
Old Aug 7, 2013 | 01:08 PM
^^ Good point and great idea!
1991whiteoutblazer
Jan 8, 2009 08:17 PM
sbmotoracer
Dec 4, 2007 08:03 PM
PLASTIKMN
Jun 20, 2006 03:29 PM
KA3AX
Apr 13, 2006 09:14 PM
MudHawg
Dec 20, 2005 12:56 PM
