Problem removing passenger side hub
Old May 20, 2013 | 11:53 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
Default Problem removing passenger side hub
So im in the process of replacing my ball joints after being in a car accident and im trying to get my passenger side hub off but i can barely get it to budge (yes, hub nut is off along with the 3 other bolts). I can get it to move about a 1/8th of an inch and that's it even with a big hub puller and breaker bar. It just becomes almost impossible to spin the puller bolt and im afraid i might break something.
Im going to guess it got damaged in the accident because that tire took a pretty good impact. So I'm lost and don't know what to try next. Ive been soaking it in pb blaster so hopefully that helps. So am i just being too gentle with it? Maybe ill just get the puller as tight as i can then use a big rubber hammer to persuade the hub out of the housing.
Any ideas are greatly appreciated.
Old May 21, 2013 | 04:39 AM
rexazz2's Avatar
Is it hanging up on the axle stub or in the stearing nuckle ?
Old May 21, 2013 | 04:42 AM
newguy's Avatar
Push it back and look, I believe there is a washer also
Old May 21, 2013 | 10:03 AM
Stephen Jay's Avatar
Stephen Jay is on a distinguished road
I did the same job the other day. A can of liquid wrench and a hammer worked fine for me. do you plan on replacing the hub too?
Old May 21, 2013 | 12:27 PM
Jakeduece's Avatar
Jakeduece is on a distinguished road
Yeah make sure you get that washer off. Also, what I usually do if the hub is hanging on the axle, is I put the axle nut on flush with the end of the stub, and then get a bfh and smack the daylight out of it. Usually does the trick.
Old May 21, 2013 | 12:39 PM
warthogdriver's Avatar
^^^+1
Make not flush with stem and then i put a 2x4 on it and smack the crap outta it.
Also try some pb blaster between hub and spindle face...that is a problem area to. Once off i use a thin layer of antisieze between hub and spindle...makes life easier down the road.
Old May 21, 2013 | 12:55 PM
Yeah i got the washer off as well. But yeah im pretty sure its hanging up on the shaft. It comes away from the knuckle but not the shaft. Ill try my 5 pound maul and a 2x4 real quick and see if that works.
Old May 21, 2013 | 01:26 PM
newguy's Avatar
Forgot that I also use a brass hammer on the shaft
upmaine
Jul 9, 2012 12:31 PM
Wexinlo
Apr 6, 2011 11:35 PM
Eric0072
Sep 11, 2008 03:13 PM
bowanna03
Jan 8, 2007 11:23 AM
hillbillyinOhio
Jul 12, 2006 04:18 AM
