Question
Old Apr 20, 2008 | 01:04 AM
4x4blazerguy's Avatar
Default Question
I have a crunk in the front suspension when I turn sharp & hit a bump or rough place in a road at slow speeds. I have grease fittings on all ball joints & they are greased. Went I'm driving & hit pot holes or rough road I hear nothing. Only sharp turn at slow speed.
I don't see anything loose, the trucks steering is tight, Nothing loose. I see there was a TSB in 2004 on cluck when applying brakes hard. Does anyone know anymore about the TSB from GM?
Any thoughts?
Old Apr 20, 2008 | 09:59 AM
portcqb's Avatar
portcqb is an unknown quantity at this point
Default RE: Question
Not sure about the TSB, but I have a thoughtcheckthat your sway bar links have nuts on them and aretight. I need to change mine in a few weeks since both nuts are missing. That will give a nice clunk on uneaven ground and some turns.
Old Apr 20, 2008 | 04:18 PM
I believe the washers are threaded. But I did go tighten them up and installed 2-5/16 uss nuts as back ups. That seemed to help still a little but better. My rubbers look good.
That could be the TSB to check sway bar to see if tight.
Let's see if someone else tunes in with other thoughts. Thanks for bring those to my attention.
Craig
2001Blue
Lifting Tech
Jan 1, 2011 07:15 PM
98Ltblazer
Apr 11, 2010 11:34 PM
Numba1Sean
May 6, 2009 11:48 PM
redfan13
Mar 11, 2008 09:37 PM
Chadoo951
May 6, 2007 07:01 PM
