Rear end clunking
Old Jan 9, 2010 | 06:58 AM
BlazerGuy2001's Avatar
Hey everyone, so i was driving yesterday and noticed a harsh clunking coming from the rear left wheel....it only happened when i was slowing to a stop or accelerating from a stop but all under 20mph. Anyway i got home and parked the thing and called the local service shop to make sure i could take it in. Well, today driving it to the shop (3 miles) it got noticeably worse.
It was doing the same clunking behavior except now when accelerating from a stop it takes the rear left wheel maybe 20-50ft before it even begins to provide power. Which is kind of a problem on michigan roads because one wheel on ice doesn't do jack squat.....but after about 20-50ft it would harshly kick in.
Well i made it to the shop but im worried about what it might be....we've put about $8k into this blazer and idk how much more money we are gonna throw at it....if it were my decision it would be whatever ti takes but its not...
Does anyone have a clue what could be wrong with it? Its a 2001 blazer ZR2 4WD
Heard back from the shop and said it felt like to them it was the rear brakes locking up...I'm not convinced
Heard back again they pulled the wheels and said the rear left caliber was missing one bolt and the other was sheared off....also the pads were missig their hardware. Does anyone know If this is an easy fix or not?
Last edited by TripleBlackBlazer; Jan 9, 2010 at 10:41 AM. Reason: Consecutive posts - Use the EDIT function if no one has replied to your last post.
Old Jan 9, 2010 | 10:42 AM
TripleBlackBlazer's Avatar
Sounds like some new bolts and hardware will do the trick unless the caliper is seized. Even then a new caliper isn't all that bad. Hardest part would be bleeding the brakes when you're done.
I'd be more concerned with why/how the bolts and hardware disappeared in the first place. Have you had any work done to it lately?
Old Jan 9, 2010 | 03:27 PM
We redid the brakes and replaced the caliber mounts however that was back in the fall I'm not sure why it would just be happening now
Old Jan 9, 2010 | 04:24 PM
IF they weren't properly torqued down to the right settings, it could've taken a week or a couple months to loosen enough to the point they are now. I believe WolfPack had a similar issue not too long ago.
Here's his issue = CLICK
blazinnzr2
Oct 26, 2015 04:00 AM
Beckyj636
Nov 26, 2012 09:54 PM
brino1
Feb 25, 2011 08:05 PM
melissa97blazer
Sep 12, 2006 09:27 AM
kwsrv@libcom.com
Sep 7, 2005 05:01 AM
