Rear-end mess!!!!!!
Old Apr 24, 2010 | 12:27 AM
rocketrich67@aol.com's Avatar
rocketrich67@aol.com is on a distinguished road
Default Rear-end mess!!!!!!
O.K.-bought a rear end for my 92 full-size blazer 4X4 off craigslist(BIG mistake!) and it is not what I was told it was! Did a # check and found out it is off a 96 to 98. Wont fit my truck. My rear end has 10" brakes the one I bought has 11". Can I buy the hardware(drums-shoes-ect.) and will it line-up with my springs and shocks?
Old Apr 25, 2010 | 03:26 PM
The spring perches you can measure quite easily. So long as the rear came from under a 1/2 ton truck, it should line up properly.
Is it the same size axle or larger? Your '92 should have the GM Corp 10-bolt rear in it.
Why not keep the brakes?
Old Apr 26, 2010 | 02:13 PM
Finally got a rear end that fits! Person said it was fine-no need to check fluid -should have! Doing 50 and it locked-up! Should I get another rear-end or re-build this one. How hard are they to re-build?
Old Apr 26, 2010 | 02:16 PM
They aren't too bad to rebuild if you have the specialized tools to set the shims properly.
Old Apr 27, 2010 | 02:40 AM
what tools would that be? could I rent them?
Old Apr 27, 2010 | 06:40 AM
Google "rear axle rebuild" and have a read through a few articles.
Old Apr 27, 2010 | 02:51 PM
Thanks swartlkk!
intoodeep95
17
Nov 9, 2012 08:53 AM
brino1
Feb 25, 2011 08:05 PM
Blazer_boy
Nov 23, 2009 03:26 PM
Red03
Suspension Tech
Sep 20, 2008 09:25 AM
strongboy2005
Feb 18, 2006 11:07 PM
