Rear leaf lift 1.5" from aftermarket leaf shackles?
BTW Did you do the swap? I was thinking it'd be easy enough for my 2 jack stands and a floor jack. I have pretty much all basic hand tools.
Thanks
So just use the floor jack on the rear diff to lift things then put the jack stands under the axle housing one for each side of the diff?
Or underneath the shock absorbers?
Thx for the help!
Thanks!!! I'm sure the bushings are good. They make no noise. Could I use the old bushings on the new 2" lift shackles? Or do new shackles come with new bushings?
Just swapped mine out. Def soak bolts on shackles top and bottom. It was a coupke hrs. Some tight spots hand tools are ideal in spots. Air gun (vibration) will help loosen accesible ones
cpolson.cp
Aug 23, 2015 05:47 PM
volfan4
Nov 28, 2009 08:04 PM
midnightmekanik
Oct 8, 2009 08:32 PM
cide
Mar 23, 2009 10:57 AM
