rear shackle question
Old Mar 13, 2009 | 04:55 PM
jeffreys25's Avatar
jeffreys25 is an unknown quantity at this point
Default rear shackle question
I recently purchased a set of shackles at autozone, the question I have is that the shackle consists of two pieces of metal that have no support in the middle. Should I have someone weld bar in the middle to provide additional support or do you think it'll be fine the way it is?
Thanks,
Jeff
Old Mar 13, 2009 | 08:00 PM
willjones's Avatar
Have someone weld it!
Old Mar 15, 2009 | 10:56 AM
jeffreys25's Avatar
is there some kind of trick that is needed to get the bolts out of the old shackles because i got the nuts off but I couldn't figure out on how to get the bolts out on my 2001 2dr blazer
Old Mar 15, 2009 | 05:08 PM
Yeah, a heavy hammer! You may have no choice but to burn them out with a torch and replace the spring bushings.
Old Mar 15, 2009 | 10:32 PM
jeffreys25's Avatar
i was going to try to hammer it but there was a black box on the drivers side right where you have to hit it, i was going to remove it but they were labeled the same as the gas lines, so i wanted to see if someone said if its ok to remove it because im kind of new to doing stuff to my cars
Old Mar 16, 2009 | 12:10 AM
AJBert's Avatar
Spray them down liberally with some PB Blaster or your choice of penetrant. Work the bolt with a wrench and get it good and loose. You may have to drop the shield for the gas tank down a couple of inches to get enough room to get the bolts out, that is, once you can get them to move.
The bolts can be a PITA but they are doable. Take a breather now and then to calm down, think things out and you'll get it done. You don't need to remove the fuel canister to get them out. Clamp down a vice grips on the bolt head tight and hammer on that instead. Much easier and less work.
FIVEHORSE
Lifting Tech
Mar 17, 2013 01:46 AM
HigherPower
Lifting Tech
Sep 12, 2011 01:30 AM
KNOFF1987
Aug 25, 2011 04:10 PM
DDBlazer4x4
Feb 18, 2011 11:38 PM
jason1978
Nov 10, 2009 01:02 AM
