rear spring shackles
Old Mar 19, 2012 | 04:45 AM
  #21
int3414's Avatar
int3414 is on a distinguished road
not az,advance auto
Old Mar 19, 2012 | 07:17 AM
  #22
missmyK5's Avatar
missmyK5 is on a distinguished road
I never thought to look at Advance auto for the bushings. I did check with them for the shackles. They didn't have them.
You need to measure the inside diameter of the spring. I got my bushings at Rubber Bushings - Leaf Spring Bushings | SD Truck Springs.
I didn't have my old shackles off yet when I ordered and took the parts reps advice and ordered the RB117. They are 1 1/2'' OD and were too small. My spring has a ID of 1 3/4'' and I had to reorder a set (4) of RB136 (1 3/4'' OD). They worked perfect but were way more expensive then the RB117s.
I looked at what Advance sells and they don't give any info on the diameter of the Moog. The Rare parts brand is a little over 1 1/2''. At least you can return them at the store if they are wrong. I have to pay shipping (around $15) to get my $18 back for the parts that were wrong.
If you check here https://blazerforum.com/forum/2nd-ge...hackles-67373/ you can see what I used to get them in the spring.
Again, if you can't get what you need from Advance I have four of the 1 1/2'' OD and two of the 1 3/4'' sitting here. If you need them I'm sure we can work something out.
Old Mar 19, 2012 | 04:00 PM
  #23
int3414's Avatar
Default heres the mother from the spring
wrong part...getting insane,the wrong part fits inside the old shell that i haven't yet butchered with the sazall.i think in my younger days,with a good torch,i would have blown the center out and not let burnning rubber bother me.
Old Mar 19, 2012 | 04:13 PM
  #24
int3414's Avatar
no real substitute for heat,pb and all the rest are for baby rust..lol
what really is eating me is my stupidly for buying this boat.
Old Mar 19, 2012 | 05:37 PM
  #25
missmyK5's Avatar
I used a drill and a propane torch to get the rubber out. All drill on the drivers side because I've always been afraid of fire near the gas tank and fill pipe. I also only cut the bolt head off ( with a grinder) and used a monkey wrench on the bolt to wiggle the bushing out after drilling and/or burning.
Mine looked the same as yours when I got it out.
Have you got the outer metal from the bushing out yet? I used a reciprocating saw to cut it part way, then had to pry it out with a screwdriver and a pry bar.
You have to measure the ID after you get the metal part of bushing out. From what I've found it's either 1 1/2'' or 1 3/4'' ID unless you have something custom.
Old Mar 19, 2012 | 06:26 PM
  #26
int3414's Avatar
back together,,,,left the outer core of the spring bushing in the spring
neversezed everything.
thanks its been fun....not really.....didnt realize you did yours last year.
thanks again!
Old Mar 19, 2012 | 06:27 PM
  #27
int3414's Avatar
oh well maybe you didnt?????
Jordan40
Suspension Tech
Nov 1, 2013 06:22 PM
someone11
Sep 12, 2013 07:39 PM
Tonyrodz
36
Mar 17, 2012 10:38 AM
step66
Apr 14, 2010 05:15 PM
95Jimmy
Sep 4, 2009 11:20 PM
