rearend
Old 10-11-2012 | 01:23 AM
badjeebus's Avatar
badjeebus is on a distinguished road
Default rearend
hello all, new to this forum,recently picked up a 85 s10 blazer 2 wheel drive with a chevy 305 turbo 350 ,but im told it has the originall rearend in the truck , it originally came with a 4 cylinder my question is anyone know what gears would be in the original rearend,,next question is are the any complete rearends out of full size trucks that would "bolt" right in without any real serious modifications to work,, any info would be greatly appreciated,
Old 10-11-2012 | 02:30 AM
50lb_cat's Avatar
I would use an online VIN decoder. If you re-gear the rear, then you will have to do the front as well. Why are you wanting to re-gear? Planning on lifting with bigger tires?
Old 10-11-2012 | 09:41 AM
badjeebus's Avatar
this is a 2 wheel drive blazer, as i put in my post, thanks
Old 10-11-2012 | 03:12 PM
50lb_cat's Avatar
Sorry, missed that the first time lol
Old 10-11-2012 | 05:00 PM
neo71665's Avatar
Honesty (and from experience) the factory rear is a time bomb. Its weak and a matter of time before it goes. Ford explorer 8.8 goes under a s-series pretty easy.V8S10.ORG • View topic - FORD 8.8 into a chevy S10!!
To answer your gear question 4.11 and 3.42 were the most common gears behind a 4 banger. Truth be told it could have been ordered with anything offered.
Old 10-12-2012 | 07:41 AM
Ugly_Monkey's Avatar
Ugly_Monkey is an unknown quantity at this point
I second the 8.8 swap. Its a rock solid rear! Get one from an ~96-01 explorer it will have disk brakes and 31-splines!
Old 10-13-2012 | 11:13 AM
badjeebus's Avatar
hey, thanks very much for all the help,,thanks monkey,,,i do have access to a 2002 rear end out of a explorer anyone know if this year will work as well for my blazer, ,,i guess my main question is what years out of explorers are the "best " fit for my build,thanks again everyone
Old 10-13-2012 | 09:22 PM
Those years were just a best guess, if the body style is the same as the ~97 then the axle should work, I think they changed things when the changed the body. search the inet for s10 8.8 and you will find a wealth of info. My axle came from a 97 4x4 4dr I believe.
Dallas1970
02-22-2019 06:05 PM
lt170chevelle
12-14-2009 01:18 PM
DFINE160
12-07-2009 01:17 PM
countilaw
02-21-2008 09:44 PM
BlazerLS95
01-15-2005 07:47 PM
