Replacing tie rods- length, spacing concern
Replacing the tie rods, both inner, outer and sleeve on a 98 S10 ZR 2. All was going well except when I place the replacement assembly next to the original assembly, one the replacement assembly the spacing inside the sleeves seems to wide and I am thinking should be somewhat centered. A picture describing the condition is attached.
Hoping forum members can take a look and share what right should look like.
The two main things to pay attention to are:
#1 The distance from center to center of the grease fittings is equal to the old assembly that you are replacing.
#2 That the gap between the ends is approximately centered in the sleeve.
The alignment shop will make the final adjustment to them.
Cassera
08-15-2014 06:59 PM
Yooper
07-26-2009 03:01 PM
