Ride Height
Old Feb 11, 2017 | 02:44 PM
cdtek101's Avatar
cdtek101 is on a distinguished road
Default Ride Height
Ride Height seems too high in front, and rough almost hard feeling going over bumps, fords and what nots ...Lol
I think when they installed the new Torsion bar Mount Bushings
they cranked it up about 1-1/2 to 2 inches too high.. which is
what I think could be the rough ride.... I know it can't be too high
or will damage parts.
Any other ideas?
Below Pics today showing sitting on as flat as I could find surface.
It's got stock suspension and all new below;
CV Axle - Left Front
Idler Arm
Pittman arm
Inner Tie rods
Outer Tie rods
Sway Bar Links
Upper / Lower Control arms w Ball Joints - Driver/Passenger side
Front Shocks
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Feb 11, 2017 | 04:28 PM
chevyriders's Avatar
Take a look at the torsion adjuster bolts, see if they're turned all the way up, or close to it. It doesn't look too high to me, but usually they sit slightly lower in the front so it could be turned up a little bit...However I'd imagine they aligned it after the work was done.
Maybe it just feels rough in comparison to what it was before because you went from worn out, soft bushings and loose steering to tight steering and new bushings.
Also "when I go over bumps, fords, and whatnot" had me dying
Old Feb 11, 2017 | 07:11 PM
cdtek101's Avatar
Good thought..
and now....see below
Lol .. FORDS ...LOL
Old Feb 12, 2017 | 02:07 AM
newguy's Avatar
1 turn of the bolt equal 1/4 inch
Old Feb 12, 2017 | 05:48 AM
cdtek101's Avatar
Yep i watched a youtube video where the guy marked the bolt so he could gauge the amount of turns...so 6 turns = 1-1/2 inch.
Is alignment required right after that ?
or should wait and drive a week ..then alignment
Old Feb 12, 2017 | 06:32 AM
newguy's Avatar
you will need a new alignment also, i would make the shop fix it for free
Old Feb 12, 2017 | 06:50 AM
cdtek101's Avatar
Oh hell yes.. they will fix for free. And fix my stabilizer links free too.
Old Feb 12, 2017 | 07:26 AM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
Picture stolen from Capt. Hook... as he would say you've got to crawl under there and measure it. Looking at it doesn't cut it...
Swartllk has an article in the tech section with all the specs
Old Feb 12, 2017 | 01:33 PM
cdtek101's Avatar
Originally Posted by CWBDDSPC
Attachment 29469
Kool, Thanks,
Capt. Hook is the authority
jcon82
Lifting Tech
Mar 16, 2009 04:34 AM
01Jimmy
Suspension Tech
Feb 14, 2009 12:56 AM
portcqb
Jan 23, 2009 10:11 AM
GregC5
Jan 8, 2009 10:50 AM
drq_92
Nov 26, 2007 09:22 PM
