shackle issues HELP
Old Nov 29, 2010 | 06:54 PM
shawncullen's Avatar
shawncullen is on a distinguished road
Question shackle issues HELP
OKAY I've got a 1994 GMC Jimmy 4wd
I'm putting on lift shackles
got one side done looks great
the other side i got the nut and bolt off the bottom end of shackle
the top bolt on the frame is not budging
it spins but after reading other threads
I've come to the conclusion that the metal sleeve is fused to the bolt
and is just spinning in the rubber
so i read up on this subject and come to the conclusion i need to torch the rubber out of the bushing then cut the sleeve out
next problem read something bout the bushing being pressed in
i don't have a press what is an alternate way to get the new bushing in?
thanks for any help/advice
theses dang shackles have turned into a head ache but the lil bit of lift is worth it
Old Nov 29, 2010 | 07:15 PM
warthogdriver's Avatar
this thread may help.
https://blazerforum.com/forum/lifting-tech-44/shackle-troubles-please-help-33638/
i didnt use a press at all just a big c clamp and 2x4
Old Nov 29, 2010 | 11:57 PM
is the top bushing the same as the one on the bottom??????
Old Nov 30, 2010 | 12:00 AM
69chevelle's Avatar
69chevelle is on a distinguished road
I was was lucky on mine but we just did a set in a 94 that was stubborn, we had 2 people, one with an air chisel hitting the threaded end of the bold(with nut on it to make sure the threads didn't get damaged) and another turning the bolt head(we used an air ratchet)
FIVEHORSE
Lifting Tech
Mar 17, 2013 01:46 AM
BlazerGuy2001
Lifting Tech
13
Feb 20, 2010 03:55 PM
95blazerlt
Lifting Tech
Feb 14, 2010 01:47 PM
nyzr21019
Lifting Tech
Sep 29, 2009 08:59 PM
warthogdriver
Lifting Tech
18
Sep 6, 2009 08:39 PM
