Slack in the Steering Wheel
Old Jul 12, 2012 | 10:35 PM
chrisgascoigne's Avatar
chrisgascoigne is on a distinguished road
Default Slack in the Steering Wheel
Curious as to what causes Slack in the Steering Wheel.
Old Jul 14, 2012 | 09:49 AM
abig84's Avatar
lots of things, play in tie rods, idler, pitman arm, bearings, under inflating tires, bad steering shaft, bad rag joint, or play in the gear box. good way to find out is have someone move the wheel back and forth a bit and lay under there and see if you can tell
Old Jul 23, 2012 | 03:05 PM
Dyspayre's Avatar
Dyspayre is on a distinguished road
Default same issue.. need part advice
I am having the same issue. after taking my blazer to what I thought was a good mechanic for a non steering related issue, now the steering is such that it's unsafe to drive. I have had a second mechanic look at it and drive it and he says I need a new Steering Box. but while looking on Rock Auto's website, I don't see a Steering Box, but I see a Steering Gear, are these the same item?
Old Jul 23, 2012 | 04:59 PM
Rottidog's Avatar
Look under steering, steering gear. It's the steering "box".
Old Jul 23, 2012 | 08:12 PM
Dyspayre's Avatar
thank you. now i just need to figure out if it's 94' or a 95'
Old Jul 25, 2012 | 02:11 PM
forestghost07's Avatar
forestghost07 is on a distinguished road
My 99 2wd has had on-center steering play (slop) since I drove it new off the lot; 'course now w/102,000 on the clock it's worse. Upper ball joints and idler arm replaced about 20,000 mi. ago, tie rods still tight as new, about to replace frt wheel bearings. Just Wondering if there's a tighter aftertmkt "box" available - anyone know? Thanks!
PS I realized how vague the Blazers steering is after acquiring (and driving alot) a 1972 MG, which @age 40 still steers tight as a go-kart, no rebuild necessary
Old Jul 26, 2012 | 07:37 PM
Dyspayre's Avatar
Default which one to get
I have now decided that I need a new Steering Gear...the only problem I'm having now, is that the one I'm looking at on Rock Auto's website also says "RWD" on it. My 95 blazer is "4WD" should I get THAT gear or is there a difference? I want to get the right one so my mechanic can finally get my truck back on the road
Old Jul 27, 2012 | 07:05 PM
big_blaze's Avatar
big_blaze is an unknown quantity at this point
make sure you get a 4x4 box if your truck is 4x4 the 2wd box is different
Old Jul 27, 2012 | 08:40 PM
Dyspayre's Avatar
I did thank you i called RockAuto direct this afternoon.
ctyler
Aug 25, 2020 04:06 PM
Redtortoise38
Aug 24, 2015 02:21 PM
litterbug
Oct 19, 2011 07:50 AM
Parilio
Sep 21, 2011 06:56 AM
caseroj
Oct 20, 2010 08:10 AM
