steering drag
Old Jul 1, 2008 | 07:42 AM
Default RE: steering drag
If you disconnect and plug the vacuum line to the actuator for the front driveshaft, this should at least disengage the front axle. To get the transfer case out of 4wd, you would need to diagnose the problems that is having. The DIY article that lastcoupe wrote will help you to pull the codes if you have a non-auto4wd transfercase which I believe is what you have.
Old Jul 1, 2008 | 09:59 AM
noom14921992's Avatar
noom14921992 is an unknown quantity at this point
thanks. i am happy that there are peopel here that are so helpful. this is much nicer.
and does swartlkk mean to just un plug the vacuum hose to the actuator do disengage the front axel?
Old Jul 1, 2008 | 10:04 AM
Yes, I mean to disconnect the vacuum line and plug it. Forgot to put vacuum line in my previous post. I have fixed it.
ORIGINAL: noom14921992
thanks. i am happy some one knows how to help people.
What the heck is that supposed to mean...? I know I don't appreciate the connotation that you are making...
turtlehumper2000
Lowering Tech
Jul 11, 2009 01:03 AM
spib
Street N Strip
29
Jul 6, 2007 03:45 PM
XBlazer01
Jul 2, 2006 03:16 PM
zero psi
Mar 5, 2006 10:09 PM
zero psi
Jan 15, 2006 07:27 PM
