steering feels stiff.
Old Sep 1, 2010 | 07:59 PM
kickme005's Avatar
Banned
kickme005 is on a distinguished road
Default steering feels stiff.
95 blazer 4wd 4door. go blazer back in feb 2010. from the time i got the blzer till now the steering made noise when i turned the wheel and felt shift. now it doesnt make noise that i noticed. but still feels still. i didnt do anything to the steering. the noise happened closer to when i got it. any ideas
Old Sep 1, 2010 | 08:09 PM
Is the pump reservoir full? Have you flushed the power steering system?
Old Sep 2, 2010 | 06:56 AM
kickme005's Avatar
Banned
reservoir is full. and what if i put in the lukes bottle of stuff for power steering. does that work?
Old Sep 2, 2010 | 01:05 PM
Thor_449's Avatar
Thor_449 is an unknown quantity at this point
That stuff semi works. It seals up leaks, to a point, but you have to realize that it is a bit thicker then normal power steering fluid so if you have crap in the resivor or lines it will just clogg it up more.
Old Sep 2, 2010 | 04:43 PM
AJBert's Avatar
Sounds like your pump may be shot.
Old Sep 3, 2010 | 10:37 PM
kickme005's Avatar
Banned
how do i check to see if the pump is shot? could it be if i just change the power steering fluid that could fix the stiffness? i want to change some of my fluids on my blazer do i just drain the fluid and just fill up or do i need to get the leftover tuff out?
Old Sep 3, 2010 | 11:06 PM
cbr995's Avatar
The best way is a flush. Suck some out, pour some in, turn the sterring wheel. Repeat until all you get is clear fluid. It's a simple explanation, yes.
drewblaze99
May 29, 2015 07:43 PM
Bobcat13
Jan 14, 2014 09:27 AM
keego
Nov 7, 2010 10:29 AM
trailblazin4kev160
Dec 26, 2009 02:21 AM
lochenjons
Suspension Tech
Aug 25, 2006 07:54 PM
