Steering stabilizer question
Old Jul 26, 2021 | 10:39 AM
BravadaJunk's Avatar
BravadaJunk is on a distinguished road
You are very welcome! Glad it worked.
Did you have any issues with the bracket on the frame? Mine was a tight fit.
Yes, I had to spread one of my u-bolts to max bracket hole adjustment to get it as close to the second "pitman arm" as I could. IT was tight both in the space needed, and getting to the nuts and bolts to install and tighten.
Old Aug 25, 2021 | 06:03 AM
chadimus06's Avatar
chadimus06 is on a distinguished road
I installed one I got from Rough Country. https://www.roughcountry.com/steerin...zer-4wd-383358
It clamps onto the center-link with two u-bolts and to a bracket that is already on the frame. To look stock, you'd have to find a ZR2 center-link with the hole in it to accept the stock steering stabilizer mount. But I don't know if the part will swap to a non-ZR2 Blazer.
I can't find any pictures of it installed but here is one of the complete unit. To locate the place where the u-bolts attach, you attach it to the frame with the one bolt then you find the mid point of the travel of the stabilizer and then attach the u-bolt end to the center-link. The bracket on the frame is likely squished together a bit and it might be a tight fit having never been used.
My 97 blazer isn’t a zr2 and it has the hole and frame bracket for a stabilizer already. Don’t really see a need for it tho
Old Aug 25, 2021 | 10:10 AM
The first gen Blazers all had the center-links with the hole for the stabilizers.
Old Aug 25, 2021 | 12:35 PM
I believe his 97 is a second gen...
Old Aug 25, 2021 | 01:01 PM
But wasn't 97 a transition year of sorts? I can see how they would use left over parts during such a time.
Old Aug 25, 2021 | 03:31 PM
94 was the last year for the first gen(I believe)
95-97 was sec gen, obd 1.5(I believe)
98-05 was sec gen obd 2.0(I believe)
Edit:
03-04 had upgrades that 98-02 didn't have(I believe)
05 was canadian only(I believe)
dharvey4651
Suspension Tech
18
Mar 14, 2018 07:41 PM
tttlesabre
Oct 9, 2012 01:59 AM
Kemp
Mar 24, 2011 08:32 PM
pj5454302
19
Feb 20, 2011 12:54 PM
BlazerLS
Aug 9, 2010 10:22 AM
