stuck axle nuts
Nope. The inboard end of the axle goes into the differential. If you hammer on the cup, the shock goes right into the differential. If the axle is seized in the hub, partially remove the hub. That will pull the axle away from the differential. Then use a wheel puller. The ram bolt fits into the cup. As the axle moves inboard, pull the hub outward. Gotta keep clearance between the end of the axle and the differential.
nofear17bmx
15
12-20-2006 03:14 AM
