Swapping out Axles
Swapping out Axles
I have an '86 Blazer
I want to run bigger tires (33's) with a vehicle that will be pretty loaded down. So I want to put stronger axles under my rig.
Are their any axles that bolt right up that are stronger? I would prefer to have some axles that are a little wider if possible.
What vehicle should I be looking for to take the axles off of?
I hope you have a fullsize. If so, it is relatively easy to get those tires to fit. You can run 33's on the stock 10-bolt axles. Any larger and you may have problems.
As far as upgrades go, you can get a Dana-60 out of a 1-ton for the front and a 14-bolt full floater rear axle from a 3/4 ton for the back and you'll be strong enough for some pretty big tires. You can also get the 14BFF from a 1-ton, but the spring perches will need to be cut off and moved because the spacing is different on a 1-ton than on a 1/2 or 3/4-ton.
BTW, please put your vehicle information in each post requesting help. You can do this either by creating a garage (link in the top menu bar) for your truck, by putting this information in your signature (via your User CP) and attaching it to your posts, or by including it with each post for help.
This is a full size blazer. I put the info on it in the "Garage"
Yep common swap is a 14bolt/dana 60. They will be a few inches wider but not much
I just found a dana 44 front and a 14 bolt rear from a suburban made in the 70's.
How good would these be?
Are they wider than the blazer axles?
cali bear 87
11-17-2012 05:02 PM
shotnva777
09-10-2011 01:14 AM
