Tie Rod Replacement
Old Sep 21, 2012 | 06:02 PM
matthewp's Avatar
matthewp is on a distinguished road
Default Tie Rod Replacement
I was getting an alignment done at my school and I noticed that my driver side tie rod ball joint had failed. So, I have to replace both the outer driver tie rod and outer passenger side tie rod as a standard procedure.
My question is should I replace the both inner (the joints closest the center of the truck) and outer (the joints closest the wheels) tie rods or will I be fine just the replacing outer tie rods?
(note: the suspension control arm ball joints were replaced about a year ago)
Old Sep 21, 2012 | 06:42 PM
serrasalmus's Avatar
serrasalmus is on a distinguished road
your that far into i would change them all just measure the current length and get to new tie rods and make them the same length then go get a alignment
nbguide
Jun 30, 2013 05:38 AM
Klturi421
Aug 2, 2011 07:21 PM
Marcin
Sep 18, 2007 07:13 AM
ckirv
Aug 28, 2007 10:03 AM
ckirv
Aug 28, 2007 09:50 AM
