toe measurement
toe measurement
I need to know what the toe needs be set at on my '93 bravada. If anyone can give me an approximate measurement, maybe even a rough measurement with a tape measure on the front and back of the tire taken from inner wheel to inner wheel. I'm not sure if a 4wd blazer has different specifications from an awd bravada but a rough measurement is better than nothing. Thanks
not sure how different the 93 is to the 95. But when I got mine I had to totally rebuild my front suspension. I went to a local junk place to make measurements. For the 4x4 i found that from the grease spiket on the inner tie rod to the grease spiket on the outter tie rod was 13 and 5/16". (thats the center of the spiket) I redid my tie rods to this setting and have since driven my truck to NY and back and it is straight and no noticeable tire wear yet.
I toed mine in about 1/2 inch and it seems fine
