torsion bar problems.....
Old Apr 14, 2011 | 08:22 PM
jdub9000's Avatar
jdub9000 is on a distinguished road
Default torsion bar problems.....
so on my 2001 4wd 4dr blazer i needed a t-bar for the left side and i found a pair at a salvage yard on a s10 truck non zr2 w/ around 90k on the truck for $60.... got them put in along with rough country upper control arms to do a 1.5" t-bar crank... my problem is i have had to completely take out the torsion key bolt to get it down to 34" at the fender lip... i used the keys that came with the blazer but i got the ones off the s10 truck w/ the t-bars... should i have used the ones that match the t-bars? also what is the stock heighth at the fender lip if anyone knows...
all info is appreiciated!!!
Old Apr 14, 2011 | 08:54 PM
NVANZEE's Avatar
Did you put the tbars on the wrong sides. There is a difference between the two. As far as stock height i cant help you as my fender lips are just under 45in.
Old Apr 14, 2011 | 08:58 PM
jdub9000's Avatar
possibly.... i wasnt 100% sure that there was a difference between the bars and of cousre the salvage yard didnt know when i asked them... ill switch sides this saturday and see what happens... not a big job to do as i found out
85s10blaze
Lifting Tech
May 15, 2024 10:02 PM
azzr2
Mar 25, 2012 04:19 PM
sledneck16
Suspension Tech
47
May 20, 2009 12:56 AM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
Bgray
Suspension Tech
Sep 10, 2006 04:45 PM
