torsion bar replacement
I have a 2000 lt 4x4 blazer with a weak driver T.Bar im looking to try and replace both bars but cant seem to find any brand new. my question is would I be able to use Tbars out of a ZR2. or is there a lift kit some where that come with Tbars cause I have checked rough country skyjack and other leading brands and no t bars so if any one has any info on what to do and best was to replace would be highly appreciated
If you google the part number of the bar you are looking for, you may be able to find a new one. When I was looking at the new ones they were running $200 to $250 per side and pretty much only the z83 smooth ride option bars were available. You certainly could replace your current bars with zr2 bars but you would want to do both sides though and you might end up with a stiffer ride. Then make sure and set the z height properly to avoid extra wear and tear.
azzr2
03-25-2012 04:19 PM
