Transfer case
Old Apr 10, 2013 | 03:23 PM
Jimmy_Blazer's Avatar
Jimmy_Blazer is on a distinguished road
Default Transfer case
On my other blazer I plan on doing a SAS and keeping the differential on the drivers side, BUT, will I be able to? How much can the stock t-case on these handle? I plan on either a 1/2 or 3/4 ton front axle with 38s. will the stock t-case be able to handle this or should I get a full size t-case or use one from a full size chevy with the differential on the passenger side?
Old Apr 10, 2013 | 03:54 PM
WitchingHour's Avatar
WitchingHour is an unknown quantity at this point
Are you doing an engine swap, as well? And, if so, what's the torque output of that engine?
Old Apr 10, 2013 | 04:14 PM
Diaita's Avatar
The engine load on the transfer case wont change much, but there will be far more strain in the transfer case when in 4wd and turning because there is more traction and leverage with bigger tires. With 35" tires my transfer case has had no issues. The Blazers already come with the bigger chain in the t/c, but I'm not sure if the '95 has the 6 pinion planetary(96+ do)
Old Apr 10, 2013 | 04:29 PM
I plan on doing a 350 swap, keeping the 4L60e for the transmission. Its a 96 Jimmy. I understand the strain issue, I wont have 4x4 engaged the entire time unless I need it. But 38-40 inch tires is what I plan on running. So should it be alright?
Old Apr 10, 2013 | 10:04 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
Yeah im sure it would be fine, the transfer cases in the blazers are pretty big. They aren't much smaller than the ones in a full-size, ive seen then side by side. But transfer cases aren't expensive at a salvage yard. Although im not 100% sure on 95 tho
Old Apr 11, 2013 | 01:09 PM
Diaita's Avatar
With a stock 350 the t/c should be fine. If you start building up the engine you will find it's limits pretty quick.
The Jeep New Process / NVG 231 Transfer Case
Old May 14, 2013 | 06:11 PM
timsawyer2002's Avatar
timsawyer2002 is an unknown quantity at this point
does anyone know what type of transfer case a 2004 chevy blazer has
Old May 14, 2013 | 06:14 PM
Default trasfer case type
can anyone tell me what type of transfer case is in a 04 chevy blazer i have griding in the transfer case when tryin to go frontwards but works fine goin backwards so i think i need a new transfer case but don't know what type to get i see that there are a few different types any help will be great
Old May 14, 2013 | 08:50 PM
blaz's Avatar
blaz is on a distinguished road
Does the dash have 2HI, 4HI, 4LO. (3 button) or 2HI, 4HI, 4LO 4AUTO (4 button)?
3 button is a np233
4 button is a np236
Flyfishen
Jun 18, 2019 11:22 AM
bensaintonge
Dec 3, 2013 08:14 AM
bob2231
Nov 6, 2005 04:40 PM
loscochinos520
May 28, 2005 11:32 PM
buckwheat
Jan 6, 2005 04:59 PM
