What gives a ZR2 the lift?
I'm sure this is a dumb question, but what makes the ZR2 sit so much higher than the LS Blazers? Is it a factory suspension lift? Body lift? Just curious. Help me if you can.
Rick
Rick
RE: What gives a ZR2 the lift?
2" larger tires (netting 1" of height)and a 2" factory suspension lift.
frames are differnet this is the most of the lift..
Right... the suspension lift is acheived by modified mounting points on teh frame for the suspension.
makes sense. Thanks fellas. Just installed add a leafs on my blazer...rear was sagging a bit. Now it sits just above level...very slightly raked look. Lovin it.
Isn't that kinda like saying what gives a F150 it's lift?
The ZR2 is a completely different vehicle than an S10 blazer to me (different frame, different axles, the tires/wheel wells difference..). It's not really a 2' suspension lift if the mounting points are different from where they lie on a S10 blazer...it's a different suspension setup right?
Edit:ok maybe not completely different, but it's obviously different enough you have to buy parts specific for a ZR2 as opposed to S10 blazer...different enough
NCSurvival
11-06-2014 05:36 AM
naveedmerchant
12-02-2013 08:41 AM
