Street N Strip Post your vacation driving stories, day at the track, breakdowns, safety issues, driving techniques, unique driving conditions, etc. STREET RACING STORIES ARE STRICTLY PROHIBITED.
Went to the track tonight
Old Nov 7, 2009 | 01:13 AM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
Default Went to the track tonight
It was me and a couple of guy from my Auto Tech class. We went to what use to be Red River Raceway tonight. Its called The dragstrip @ Thunder Road now. Quickest time of the night was a silver 69 Camaro with black stripes that ran a 7.88@174! Only one wreck. A pinto snapped both axles and slid 180* into the wall. One of the tires ran a 16.?? at like 21mph lmao. There were a few first gen S10's that were pretty f'in quick...9's and 10's IIRC
I didn't to all that bad. Better than I expected from a Blazer with 161k miles and low compression on BFG Radial T/A's. My best run was:
60'......2.268
330'....6.531
1/8......10.095
1000.....
1/4......15.883
MPH.....84.40
Old Nov 7, 2009 | 02:19 PM
oktain's Avatar
Sounds like fun!
Not a bad time either for a slightly modified poor running Blazer either.
Old Nov 7, 2009 | 05:10 PM
I wouldn't say it runs poorly. I still get 17.8mpg avg out of every tank. My compression may not be as low as I think. It's only one cylinder that's lower than the rest. When I did the test, for each cyl, I only let it turn over 3 times before I checked the gauge. Most people I've talked to said I should let it turn over 4 or 5. Even at 3, I had ~120 psi except for cyl 4, which had 85 or so.
It runs like a raped ape. Feels better than it did when I got it at around 95k miles.
Old Nov 8, 2009 | 01:21 PM
oktain's Avatar
Oh... nice do you have a pcm tune?
Old Nov 8, 2009 | 07:33 PM
Nope, no tune. That's next on the list. I'm guessing PCMforless.com is the way to go?
According to the four or five hp estimators I used, I'm hopefully getting between 180-190 to the wheels. That may be wishful thinking, though.
That with the k&n, 2.5" mandrel dynomax catback, and cat replaced with 2.5" test pipe. Brand new AC Delco ignition(dissy, cap and rotor, coil, plugs, and wires), brand new updated mpfi spider ***'y, and a brand new fuel pump.
Old Nov 30, 2009 | 05:13 PM
dirttrax's Avatar
dirttrax is on a distinguished road
i see u have the k&n already. if you can get away with it gut the cat converter. makes pretty good gains in hp. o2 sensor spits a code every now and then but doesnt hurt the gas milage. you can order and under driven pulley set from O'reilly auto parts for a 350 and it will fit ($119.00). helps get back power you loose on the a/c water, pump, power steering. with the k&n the cat gutted and the pullys i put down 176hp at the wheels(unless the dyno was wrong) on my friends dyno and 9.97 1/8 mile. low profile tires changes gear ratio some so that may have helped those numbers. i get 23 mpg if i drive easy on the hwy but alot of it has to do with being lowered. (reduces air drag under the truck)
Old Jan 7, 2010 | 12:49 AM
The cat is completely gone, as I stated in the post above yours.
midnightbluS10
Street N Strip
May 6, 2010 06:15 PM
98Ltblazer
Apr 16, 2010 06:14 PM
Rottidog
Mar 24, 2010 08:38 PM
95Blzr
Nov 17, 2008 10:13 PM
blazerxtreme1
Street N Strip
22
Jun 16, 2008 06:19 AM
