Suspension Tech Have a question about modifying your suspension? Ask it here.
1.5" t-bar and 2" shackles
Old Feb 22, 2009 | 08:28 PM
Cavalier z24's Avatar
Cavalier z24 is on a distinguished road
Default 1.5" t-bar and 2" shackles
Ok i just bought 2" shackles online and will be here in a few days
Now do shackles make the ride rougher at all and how much rougher will a 1.5" t-bar lift be?
Old Feb 22, 2009 | 09:13 PM
WolfPack's Avatar
Default RE: 1.5" t-bar and 2" shackles
Shackles do not effect the ride, but the tbar crank will. I loved the stiffer ride after the lift though. The only bad thing is that the shocks will top out easier. I only notice it on speed bumps though. Take a speed bump too fast, and you get an almightly clunk with a hard drop on your nose...you get used to it though
Not sure on a DIY for a 3'-er on a 1st gen..
Old Feb 22, 2009 | 09:16 PM
thanks wolfpack, could i just get better shocks like longer ones? or is it not that bad of rough ride to even bother with ?
Old Feb 22, 2009 | 09:17 PM
WolfPack's Avatar
Id say its personal preference...I dont feel the need to get new shocks as it does not cause me enough problems..but you might. Butttttt if you do, longer shocks will fix the problem. 2' lift shocks would be ideal
Old Feb 22, 2009 | 09:41 PM
Thanks wolfpack
By the way i love your blazer, How much did your 2" body lift cost to put on or did you do it your self?
Old Feb 22, 2009 | 09:58 PM
WolfPack's Avatar
I did it myself! Its not too hard at all...just alot of checking, test fitting, checking again, and repeating steps
But I did check with 4 Wheel Parts...they have a book with cost/times involved...for a 2' body lift on a S10 blazer 95+ its $500 for labor. Not sure how much different it would be for a 1st gen though!
Old Feb 22, 2009 | 10:08 PM
ok thanks
jdespain
Lifting Tech
14
Jan 29, 2010 10:07 AM
dirtydave
Suspension Tech
Dec 18, 2009 04:21 PM
moose4553478
Lifting Tech
Oct 24, 2009 12:41 AM
Blindthieves
Suspension Tech
Mar 6, 2007 12:41 AM
jimmyboy
Tires and Wheels
Dec 4, 2006 09:46 PM
