Suspension Tech Have a question about modifying your suspension? Ask it here.
35's on a full size
Old Dec 11, 2006 | 12:07 AM
trailblazr81's Avatar
trailblazr81 is an unknown quantity at this point
Default 35's on a full size
Is it possable to run 35's on a 92-94 full size Blazer without spending $1000+ on a lift kit? Maybe a 3" body lift and a Skyjacker 2.5" suspension lift. Thats 5.5 inches, so maybe a little trimming? I have some almost new 35" BFG mud tires and would like to use them. I am wanting to replace my 73 K20 with a newer fullsize Blazer with fuel injection. And the IFS rigs ride sooooo much better than the solid axle with lift.
Old Dec 11, 2006 | 12:50 AM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default RE: 35's on a full size
pm chevy lover and see what hes runnin....
Old Dec 11, 2006 | 12:22 PM
cherryred4x4's Avatar
cherryred4x4 is an unknown quantity at this point
I saw a chart somewhere on 4wheelparts.com that showed vehicles and how much lift was needed to fit each tire size, or how much lift + trimming. For the 92-94 fullsize Blazer you can look at the Silverado if they dont list Blazer.
Old Dec 11, 2006 | 10:09 PM
ORIGINAL: cherryred4x4
Those are always too conservative. For instance they say you need 6" lift to clear 35's on a solid axle full size Chevy and Ive run 35's on 2 K5 Blazers and a K20 with 4" and have had no problems. Even when wheeling.
Anyways I'll try a 3" body lift and maybe crank the torsion bars 1" then out with the sawzall and hammer.
Old Dec 15, 2006 | 07:56 PM
lochenjons's Avatar
lochenjons is an unknown quantity at this point
Yeah its easily possible. esepecially with bfg since those are a little smaller than what the size reads. but really you should sell your tires to me since I'm looking to do the same thing. I have a 4" lift and 33"s look way small. My friend has i think a 4" and hes got swampers on his, they rub tho. But only on the right side of the fender closest to the back and his tires have bent that back enough its not even an issue now
admathi
Dec 15, 2019 04:24 PM
goerzenl
Nov 1, 2010 10:14 PM
zero psi
Suspension Tech
Mar 10, 2005 10:30 PM
zero psi
Feb 3, 2005 05:57 PM
Wolf~K5
Dec 13, 2004 11:05 PM
