drivers side camber
I have discovered I am having the same problem. I just replaced both uppers and did an alignment on my garages machine. even with the cam lobe completely turned in I just can't get rid of the neg. camber. I am thinking I just need to replace all ball joints, tie rods and front struts. truck has 200K plus on the chassis so I guess I'll be better off anyways.
The camber/caster lobes are on the front upper control arm bolt. The bushings are eccentric so if you loosen the nut androtate the bolt head it will turn the camber lobe and move the upper control arm in/out. This is the only adjustment in the front for camber/caster.
upmaine
Jul 9, 2012 12:31 PM
Wexinlo
Apr 6, 2011 11:35 PM
hillbillyinOhio
Jul 12, 2006 04:18 AM
fruccoman
Feb 15, 2006 07:08 PM
